PulseTech Pulse Charge Monitor Distribution System
Posted: Wed Jan 23, 2013 9:44 pm
by milesdzyn
Saw this and thought this would interest some of you guys looking for 12v and 24v tapping plus battery maintenance all in one unit.
Described as: Three component system that provides a way to efficiently distribute optimum power for both 12-Volt and 24-Volt multiple components. The Power Distribution Unit allows you to determine what level of amperage protection each device connected requires and then connect to the corresponding terminal. Four 12-Volt taps and eight 24-Volt taps are available for use. Includes solar charging panel and push to test battery state of charge gauge. waterproof and weather proof.
Sounds like a great easy solution and since it's made for the US military it should be built well. I don't have personal experience with this so I can't answer any questions.
http://www.armysurpluswarehouse.com/mil ... ystem.html
Miles
Re: PulseTech Pulse Charge Monitor Distribution System
Posted: Thu Jan 24, 2013 8:11 am
by audiocontr
i wonder what the amperage ratings are...
