Far away of any infrastructure.
Four years ago I changed the lower kingpin bearing. The original parts were not available so I changed to a kingpin reversion kit which uses the Landrover tappered roller bearing. That wasn´t a good Idea because the bad roads of Albania killed them. If there is a little bearing clearance every road hole is like a blow of a hammer. And finally the bolt broke.
So I changed back to original rebuild parts which are now available.
What I want to say: check bearing clearance of the knuckle !
