dry carb bowls
Posted: Mon Jan 28, 2013 6:38 pm
by Pols497
I have been noticing that my 712 on startups after it has been setting for acouple of weeks that I have to pump the throttle to keep it running for a bit. The other day she would not start at all. I checked the carbs when I pumped the throttle and no gas was shooting down thru the venturas. My question is, what would allow the fuel to drain out of the bowls. Any help on this would greatly be appreciated. :?:
Re: dry carb bowls
Posted: Tue Jan 29, 2013 11:46 am
by spandit
It probably just evaporates if not driven for 2 weeks
Re: dry carb bowls
Posted: Tue Jan 29, 2013 1:38 pm
I always have to pump a few times to get the bowls full after sitting for awhile. Never thought of it as a problem. For a test leave a little gas in a pan outside and check it in a few days, just nothing there.
Re: dry carb bowls
Posted: Tue Jan 29, 2013 6:20 pm
by M Wehrman
An electric fuel pump will cure that,a few of our club members have them,work fine.
Re: dry carb bowls
Posted: Wed Feb 06, 2013 6:56 am
by Pols497
Thanks guys, I think I might look into the electronic fuel pump install.
Re: dry carb bowls
Posted: Wed Feb 06, 2013 12:00 pm
by djw
This one looks like it might be a good choice if you want to go that way. 24V 4-6 psi max.
http://www.aircraftspruce.com/catalog/e ... tpumps.php
Re: dry carb bowls
Posted: Thu Feb 07, 2013 5:01 pm
by M Wehrman
I've had good luck with that brand. The price is about right.
Re: dry carb bowls
Posted: Fri Feb 08, 2013 10:35 am
by Middlebury_Pinz
I've used Facet fuel pumps for well over 20 years when upgrading Porsches to Weber carbs or replacing a defective pump on a carbureted 911 and they work great! Very quiet and reliable. As I recall, we had to use an adjustable fuel pressure regulator as the stock output was way to high and would flood it out. I remember that we used a Holley inline fuel pressure regulator to get it down to approx. 1.50 psi. there were several available with different adjustment ranges. Does anyone know the ideal fuel pressure range for the stock Pinz carbs and I will look them up and post it.
I'm looking at a couple of these myself
. Didn't know they made them in 24 vdc and it makes them even more attractive.
Would you leave the existing mechanical fuel pump in place or remove it and install a blanking cover?
Re: dry carb bowls
Posted: Fri Feb 08, 2013 10:47 am
by djw
Re: dry carb bowls
Posted: Fri Feb 08, 2013 11:51 am
This looks to be getting expensive and that the solution is to drive it a bit more often and just pump the pedal a few times...lots cheaper than trying to circumvent the design of the pinz..
Just my humble opinion.
or, get one of these
http://cgi.ebay.com/ebaymotors/Pinzgaue ... 2c6c4bf901
Has a 6 cyl and even a Benz emblem on the grille.
Re: dry carb bowls
Posted: Fri Feb 08, 2013 2:03 pm
by djw
Cost not too bad if you suspect you've got a failed or failing pump to deal with.
Choices seem to be rebuilding it (SAV $80 kit)
Or buying a new Pinz pump from SAV for $435
Or their used Pinz pump $125
Or their rebuilt pump for $179
Or a VW pump, but the Beck Arnley ones where you can rotate the top vs the stamped ones are getting difficult to find.
Electric pump for $42 + a $30 regulator does not seem that bad.
Re: dry carb bowls
Posted: Fri Feb 08, 2013 2:31 pm
I bought a spare one from Napa for $30.
Re: dry carb bowls
Posted: Fri Feb 08, 2013 2:36 pm
by djw
krick3tt wrote:I bought a spare one from Napa for $30.
Me too last year, and the one I got from them wouldn't fit. The ones where you can unbolt the top and rotate them appear to be unobtainium now.
http://www.real4x4forums.com/PinzgauerB ... f=5&t=7539
As one of the posters suggested, the crimped top ones are NFG for a Pinz install. Apparently the one you got is not what they now have?
Re: dry carb bowls
Posted: Fri Feb 08, 2013 4:32 pm
The one I got is exactly like the one in the pinz. When i went to the desk to order it the pic in their computer showed some pressed together thing but that is not what I got when the order cane in.
I can take this one apart and rotate the top where the inlet and outlet pipes are and it is rebuildable.
I only got this as an emergency spare. I also carry a rebuild kit with the gaskets and such but trying to rebuild one in the middle of nowhere did not sit as well as R&R to get back to civilization.
Re: dry carb bowls
Posted: Fri Feb 08, 2013 9:37 pm
krick3tt wrote:This looks to be getting expensive and that the solution is to drive it a bit more often and just pump the pedal a few times...lots cheaper than trying to circumvent the design of the pinz..
Wow what mess that would seem to be!
