Atik G wheels
Anything DIESEL driveline, axle, suspension related goes here.
gunipinzmutt
Italy
Atik G wheels
Post by gunipinzmutt »
The most common alu rims seen on TDs are Atik from G-wagen. Are there adaptation jobs to be done? Are longer bolts needed?
Pinz: 710 m, 710 ms, 710 k, 712 m fla, 712 k, 716 m, 718 m san, 716 k, 718 rehinbraun
Haflinger: 700, 703
G: 250, 270, 400, 350
Unimog 406
M825, M151 A2, M416
Fiat Panda 141A 4x4
Fresia F18
ExpeditionImports
Re: Atik G wheels
Post by ExpeditionImports »
We are using a wheel on our tour conversions that is made in the UK for the Sprinter vans. They are relatively inexpensive, look good and are pretty much a bolt on conversion. You will have to change out the wheel studs to a Conical Lugbolt, we found the correct ones in Italy! Retail price in the U.S. is about $175 a wheel and $2 a lug bolt.
Scott
Vallejo, California
www.expedition-imports.com
fesm_ndt
Re: Atik G wheels
Post by fesm_ndt »
G Wagen rims fit if you ream out the mounting holes.
I cant recall how much but doable
Porsche ones don't fit as the central hub bore was too small. I just happened to get some Porsche rims to play with one day 8)
Regards
(Project Gimpy 2)
Re: Atik G wheels
I can't recall for sure but aren't the stock steel/military Gwagen wheels the same as the steel TD wheels? Like the green ones on the back of that pic?
Profpinz
Re: Atik G wheels
Post by Profpinz »
This is what Magna Steyr/Mercedes are fitting to all the Australian Military G-Wagens.
1997, 718 6X6 Pinzgauer
Re: Atik G wheels
I like the older Euro/rest of the world military, or those newer Canadian mil. version:
Profpinz
Re: Atik G wheels
Post by Profpinz »
The Hutchinson Wheels are my all time favourites (Canadian G) but at 876 euro each (I have seen them available a little cheaper from a few specialist suppliers) I think I'II be waiting for a Tattslotto win before I buy any.
http://www.puch.at/en/spare-parts/acces ... spx?LNG=en
Re: Atik G wheels
Hutchinson's are great but once you go through rocks and bash up the 15 stud threads (x4 = 60) you'll be lucky to get them off without breaking them!
Some Hutchinson's come with the plastic nut caps but not a great solution.
5-27-2016 3-50-47 PM.png (109.72 KiB) Viewed 8907 times
