Then the pinz has been hard to start, cranking slowly, but then catching and starting.
But this weekend, I went to start the Pinz and as soon as I turned hit the starter button, the lights on the dash dimmed. I pulled open the battery box, and saw smoke. Upon closer examination I saw that the positive voltage terminal was burnt and the battery has a crack in it. The terminal connector was burnt and melted.
Here is the battery terminal:
I can't decide it there must be a short or if this was caused by the starter current with a bad connection.
I will check the charging voltage as soon as I get new batteries. But before I put new batteries in the Pinz, is there anything I should check as a possible short? I traced all the wiring from the battery box to the starter, and did not find anything that looked burnt. (I assume that a short that can melt a battery terminal should have some burnt area around the short.) Could my starter have caused this?
Thanks for any ideas!
Timothy
