No fire
Posted: Sun May 19, 2013 8:20 pm
Just completed an annual tune. Valves, carbs, timing, and plugs. Same distributor,new rotor, same plug wires. The wires, distributor, and coil date to 2005 and 30K ago. I replaced the rotor with an identical spare. the old one had cracked where it indexed on the distributor shaft. The timing was at 12 BTDC.
A week ago I was taking my wife and kids to the beach on Mothers Day, a few days after the tune up, when three miles from the house I had a few back/misfires and then the engine died. It would crank but no ignition. I came home on a strap behind my neighbor's pick up. Bad Mothers Day.
That night I had an inch long spark from the coil but weak spark at the plugs. I changed the plugs and set the timing to 10 degrees BTDC. It ran strong until tonight when I went out for wings about 8 miles from my house. On the way home it did the same thing. I came home behind my other neighbors's truck.
So, now I suspect the coil. Your thoughts? Thanks for you time. - Buzz
