LED flood lights and mount
Posted: Mon Jun 03, 2013 7:52 pm
by norcal pinz
Re: LED flood lights and mount
Posted: Wed Jun 12, 2013 11:54 pm
by norcal pinz
Posted: Thu Jun 13, 2013 10:28 am
Good looking mount and there is still room for a camera set up. How did you do the electrical?
Posted: Thu Jun 13, 2013 7:24 pm
by norcal pinz
connected it to the big red wire behind the dash ,24V toggle,then grounded it to the body in the cab.
Posted: Sun Aug 11, 2013 12:35 pm
by GenevaPinz
Norcal, I will post pictures of my own LED lights mount as it answers a question of yours (here:
http://www.real4x4forums.com/PinzgauerB ... f=9&t=8041).
As a picture is worth a thousand words, I will save myself some typing:
The mount is held in place by the bolts that hold the windshield hinges:
The little markers are here as a replacement for the parking lights, which I lost when I switched to Trucklite LED headlights. All wires go through the hole for the top bolt (passenger side) originally used to keep in place the antenna mast holders (which you used to mount your lights).
The LED bar is a Rigid Industries 50" bar, SR (Single Row) series.
I need to finish fabricating brackets to hold the light bar in place, the stock ones are too short and the windshield washer squirts the bottom of the light bar...
Posted: Sun Aug 11, 2013 12:52 pm
by compunerdy
I like it..
Posted: Sun Aug 11, 2013 6:52 pm
Wow that is nice!
Posted: Sun Aug 11, 2013 7:47 pm
Where did you source the three pronged hole bolts? Not really sure what they are called.
Those look like a very secure way to keep the light bar on your vehicle.
Posted: Sun Aug 11, 2013 11:00 pm
krick3tt wrote:Where did you source the three pronged hole bolts? Not really sure what they are called.
I'm also curious about the fasteners you used. I've found drilled head machine screws with 2 holes at Amazon (
http://www.amazon.com/dp/B00DD41CVG/ref=biss_dp_sa1 )
but I've never seen the 3 hole type.
Posted: Mon Aug 12, 2013 2:54 am
by GenevaPinz
It was a bit of a treasure hunt to find tamper-proof bolts in the right diameter and length, and for once I found a supplier on my side of the pond, in France:
http://www.vis-antivandale.com/2-vis-antivol-metaux
They are not very well stocked, the prices are quite steep (even though I steered well clear of the titanium bolts) and they have an order minimum of EUR 50.00, but I ended up buying a few with the matching three-pronged bits.
While searching I found a few other suppliers in the UK or the US, but it was either sale in bulk by box of 100, or they did not have the right dimensions in metric.
Making it more than a 30-second job to take the mount or the light apart is definitely a good thing, these LED bars are not exactly given.
Posted: Mon Aug 12, 2013 4:06 pm
by totaljoint
Now, to find the matching driver!
