License Plate Lighting
Posted: Mon Jun 03, 2013 9:17 pm
by berger
Hey Guys .
While going over my truck today, I discovered that my plate bulbs weren't on. I opened them up an found one that appeared to be blown but the other seemed fine. Do both need to functional for them to light up? If not, is it hard to trace these wires?
I am not sure if they have been out for a while, or if the heavy rain I went through knocked them out. I am thinking the former.
On a positive note, the truck is running fine again. Regardless of the civi adapter plate covering the weep holes in the dizzy base, I think moisture still gets in there....and my wiper motor is not shot!! :D
Sent from my Mobile
Re: License Plate Lighting
Posted: Mon Jun 03, 2013 9:47 pm
I think they're parallel, not in series. What's the voltage reading at the lamp socket? Got 24?
Posted: Tue Jun 04, 2013 5:54 am
by berger
undysworld wrote:I think they're parallel, not in series. What's the voltage reading at the lamp socket? Got 24?
When measuring at the socket, the ground is the sidewall correct?
Posted: Tue Jun 04, 2013 6:57 am
Yup, on any negative-ground vehicle, the chassis will typically be your ground. (Some older machinery is positive-grounded.) Your circuit is from the positive 24v being supplied through the wire, through the device like your light, and negative grounded via the chassis.
One lamp terminal should show zero ohms to ground, and the other terminal should have 24v when turned on. If either is not present, the bulb will not illuminate.
Posted: Tue Jun 04, 2013 9:42 am
by berger
Thanks!
I am placing an order with SAV, and I just wanted to be sure the bulbs are SAV3508. The same used in the dash etc?
Posted: Tue Jun 04, 2013 10:31 am
yup
see group 9-80 same part number 902.0759
Posted: Wed Jun 05, 2013 12:22 am
by Thomas-E
A replacement 24 volt bulb for the license light is, US #1818.
This number is common in the US.
SUPERBRIGHT LEDS Sells an led replacement, looks nice in the panel 8), Item BA9S
in many colors.
Posted: Wed Jun 05, 2013 6:34 am
I do not believe those replacement bulbs work in all locations on the Pinz. Seems to me I recall the physical size is too big on those 1818 bulbs. ??
Posted: Wed Jun 05, 2013 6:54 am
by berger
Thanks guys.
I just happen to have a packet of 20 #1818 from my Iltis, and they are to long for the plate fixture. I will pick up a few from SAV.
Posted: Thu Jun 06, 2013 6:26 pm
by totaljoint
Use LED in the plate light. Again from SUPERBRIGHT LEDS.
No one will miss you from behind with those!
Posted: Thu Jun 06, 2013 6:58 pm
totaljoint wrote:Use LED in the plate light. Again from SUPERBRIGHT LEDS.
Ditto! They are definitely nice.
Posted: Thu Jun 06, 2013 7:36 pm
What model number did you use?
Posted: Thu Jun 06, 2013 7:46 pm
by berger
I have to determine why they aren't lighting first...
Sent from my Mobile
Posted: Thu Jun 06, 2013 9:40 pm
by totaljoint
See these threads for license plate lights:
viewtopic.php?f=14&t=6671&hilit=superbright
viewtopic.php?f=4&t=3643&hilit=superbright
One of the best references on LED's and their modification and use as dash lights:
viewtopic.php?f=14&t=4928&p=34932&hilit=led#p34932
Posted: Thu Jun 06, 2013 11:15 pm
by djw
I did all of the inside lights, panel, instrument, and license plate with superbright LED bulbs in my K.
All the panel, instrument, and locker lights had to have the bulb dome lopped about in half with a dremel cut-off wheel to fit. The map light over the glovebox fits without modification. The mod for the panel bulbs is easy to do (did not see that prior thread though, but that is what I did). All mine are white but my lenses were not faded so they look normal.
License plate lights were the bright white and they are indeed very bright stark white as in the photo above.
The interior I originally did with the bright whites. I found the the color temp was just too ghostly stark white so I moved them to the blue fixtures and put warm white LEDs in the front, middle, and aft clear overheads - much more pleasing color cast and more like the original incandescent bulbs.
Best of all they don't heat up the fixtures if they are on for a long while. The Austrian refurbs probably use a different o/h fixture (Hella 1357) than the Swiss, not sure about license plate lights (mine uses a festoon style bulb), so I doubt my bulb numbers are the same.
