Easiest way to work on dash wiring??
Posted: Fri Jun 21, 2013 12:21 am
by compunerdy
Is there a easy way to get to the gauge wires, etc or does everyone just do a contortionist act to get to them?
Re: Easiest way to work on dash wiring??
Posted: Fri Jun 21, 2013 7:12 am
by michaelh712
"easy way" = oxymoron. I remove the steering wheel and tilt the dash plate. Still a pain with big hands.
Posted: Fri Jun 21, 2013 10:44 am
I always remove the kneepad and then just work up from underneath for the simple projects.
Posted: Fri Jun 21, 2013 12:02 pm
by compunerdy
I removed the kneepad which definitely helped. I also tried to lift the panel up but hit the steering wheel so I might try removing that next.
Can anyone explain how the funky fasters around the outside are supposed to work? Mine just pulled straight out.
Posted: Fri Jun 21, 2013 12:06 pm
by berger
compunerdy wrote:I removed the kneepad which definitely helped. I also tried to lift the panel up but hit the steering wheel so I might try removing that next.
They are supposed to lock in place when you tighten the screw. My locker panel does the same, lift right out.
Posted: Fri Jun 21, 2013 2:03 pm
by pcolette
compunerdy wrote:Can anyone explain how the funky fasters around the outside are supposed to work? Mine just pulled straight out.
Mine just pulled out also. I took them completely off and inserted well nuts in the dash shroud and just use phillips screws to hold the dash panel in place.
Posted: Fri Jun 21, 2013 4:43 pm
by djw
If you're curious, those little thingies are Vibrex fasteners. They're pretty neat if the rubber parts are not all dried out and they still work. 1/2 turn clockwise and they click locked, the other way unlocked. A strong hold and quick release if they work as designed.
SAV actually has them 7111710110 and I have no idea where they source them since they appear to be pretty obscure. You can always go the well-nut route, but it is nice to know the new OEM parts can be had.
http://books.google.com/books?id=8OdSAA ... ner&f=true
+1 on removing the steering wheel if you can't see what you need from underneath.
