Turn Signal info
Posted: Fri Jun 28, 2013 1:38 am
by compunerdy
I ordered a new turn signal switch 211953513G from Airhead parts. Here is the wiring layout for it.
Switch - Pinz
brown wire - ground
1 to 2 butt connectors
black w/white stripe - Black w/white stripe
black w/green stripe - black w/green stripe
5 terminal butt connector
yellow w/black stripe - Black w/white stripe
brown w/white stripe - Brown
red w/black stripe - Black w/green stripe
black w/white stripe - white
gray w/black stripe - Purple
Re: Turn Signal info
Posted: Fri Jun 28, 2013 8:23 am
by Buzz
Thanks for posting this. I think I need a new turn switch and this will help.
Posted: Fri Jun 28, 2013 8:38 am
by berger
Posted: Fri Jun 28, 2013 1:43 pm
by compunerdy
I did not post a link as the site was down. I am not sure the "guts only" will work but if someone tries it then post it up..
Here is the link for the one I ordered.
http://www.airheadparts.com/vintage-vw- ... 11953513-g
I also forgot to mention that you need to re-use the old half moon metal piece or shave the nipple off the new one since our tubes do not have a locating hole.
As far as I could tell you can reuse the old mount with the new switch or remove the steering wheel and swap in the new one.
Posted: Fri Jun 28, 2013 1:48 pm
You have to be careful of the "guts only " option as there are variations in the housings. I have found 2 types of switch internals and they do not interchange into the housings. Best to buy the switch complete, only the housing part around the steering shaft can be re used with either type.
These switches also work for the C303 with minor mods.
Posted: Sun Apr 12, 2015 7:19 pm
by Maxf
Hey Compunerdy - Thanks for the wire colors. Just installed a replacement intern set from Airhead.
Couldn't have done it without you man. Works great.
Cheers! Maxf
Posted: Mon Apr 13, 2015 9:52 am
by pinzinator
I installed that switch on my 710, it workes fine and the wire colors match up. Very easy to do!
