Intrument Panel Indicators
Posted: Fri Jun 28, 2013 2:04 pm
by compunerdy
Would anyone else be interested in something like this?
http://www.newvintageusa.com/images/91017-01.jpg
I am going to do something along these lines but for just me I probably will not worry about making it fit the stock dash plate but if others are interested then we might consider a group buy.
We could have it setup with 24v LED's and the stock graphics or custom ones.. On mine I plan to move the 4x4 and diff locker lights to here as well.
Re: Intrument Panel Indicators
Posted: Mon Jul 01, 2013 3:57 pm
by compunerdy
Here is what I came up with. I decided to just use the standard indicator cutout for now and might change it up again in the future.
Posted: Wed Jul 03, 2013 5:28 pm
by mm58
What's the gas pump indicator? Are you going to have a low fuel sensor?
Posted: Wed Jul 03, 2013 8:41 pm
Same question applies to the left and right directionals. Isn't it just a single lamp on the stock panel? You might have to do some electrical modifications, it sounds like.
It's certainly newer looking. Not so say you aren't onto an interesting idea, but pretty much every time I think up some modification to make, I come to realize the brilliance of the original design. It's made me appreciate the original design that much more.
I'll be interested to learn how your project works out. Please keep us informed.
Posted: Wed Jul 03, 2013 9:42 pm
by compunerdy
Yes the gas pump will be for a low gas warning light.
The turn signals are already on separate circuits so very easy to hook up plus they will both blink when the flashers are on since they are tied into the same circuit.
I should have some progress pics in a week or so.
Posted: Wed Jul 24, 2013 10:20 pm
by compunerdy
Still playing with diffusers as my LED's are a bit bright but here is where I am at so far. The colors do not look as washed out as the camera makes it look. The red LED's blink to catch your attention better. I might try hooking a buzzer to the RPM light as well for a audio alert.
Posted: Thu Jul 25, 2013 3:08 pm
by mockingbird812
Impressive work Tim :!:
Posted: Thu Aug 15, 2013 11:53 pm
by Nomad
Personally, I really like this!!
Posted: Thu Sep 05, 2013 11:32 pm
by compunerdy
Here is a video showing the turn and high beam lights in action.. still need to hook up the rest.
http://www.thecustomsabershop.com/images/pinzturn.mpg
Posted: Fri Sep 06, 2013 1:45 pm
by mopar
compunerdy wrote:Here is a video showing the turn and high beam lights in action.. still need to hook up the rest.
It looks very nice!!! Is your dash panel clear plexi glass??
Posted: Fri Sep 06, 2013 2:44 pm
by compunerdy
Currently it is acrylic. I have a laser cuter/engraver and it made a easy way to test fit locations, fit, etc..
