Please fix the sleeves on aftermarket shocks.
Posted: Mon Jul 15, 2013 6:55 pm
by audiocontr
Such a royal pain in the ass to do the fronts. That top bolt sucks!!
One minute per rear shock, but I'm on hours for the front. I need a second set of hands!
Re: Please fix the sleeves on aftermarket shocks.
Posted: Mon Jul 15, 2013 10:38 pm
by berger
Ya, they were a pain. Removing the sleeves was the worst part. Inserting them was a pain too, but I was more concerned with damaging the rubber bushing, so I lubed the hell out if it.
Sent from my Mobile
Posted: Tue Jul 16, 2013 5:20 am
by audiocontr
Some slide right out! Others take a ton of messaging and its a crapshoot. I'm still working on the drivers side after thinking the bolt went in just far enough to lock into the sleeve. Now the whole sleeve is rotating and I cannot get the bolt back out. I can't push it in any further because I have no room. I'm nervous of damaging the insert but its the only choice I have to get it back out, all due to a crappy sizing of a fricken shock sleeve.
It's partially my fault for not testing the bolt in the sleeve before installing.
Posted: Tue Jul 16, 2013 9:12 am
Just adding in Bergers Tech Post re: Aftermarket shock install and sleeve issue for reference.
It seems crazy that they are incorrect when the manufacturer is to have 'customized' them for the Pinz
viewtopic.php?f=22&t=8221&p=60066&hilit=shock#p60066
Posted: Wed Jul 17, 2013 6:23 am
by stiffler4444
I found a healthy does of Honey Goo helped to start it, much like Berger used silicone. I then eased it in with the assistance of a vice.
tx Dave
Posted: Wed Jul 17, 2013 7:20 am
by ExpeditionImports
Hi guys,
Today we receive the first run of Doetsch shocks with the factory spec sleeve in both the top and the bottom. In the same order is a batch of extra sleeves. Originally the upper sleeve was fine, however sometime over the last year they changed the manufacture of the upper sleeve and the bolt hole sizing went out of spec, making it more difficult on install.
This should be handled with this new manufacturing update.
Scott
Posted: Wed Jul 17, 2013 7:46 am
by berger
ExpeditionImports wrote:Hi guys,
Scott
That is good news Scott! Thanks for updating us! :D
Posted: Wed Jul 17, 2013 1:22 pm
Shwing
Nice Scott!
