Valve gone wild
Posted: Thu Jul 25, 2013 5:29 pm
Well, last week had #3 exhaust valve go rogue on the freeway, The head of the valve snapped off and dove through the piston after beating the head , cylinder and piston into submission. So I have spent the last several days digging through my spares to complete a replacement.
Blown engine was put in 7+ years and 35,000 miles ago (used long block) after a cam plug failed wiping out all 4 pistons on the original engine.
Luckily, I had a spare engine with new bearings and prototype (HP)cam grind partially built on the stand(the original engine). Managed to scrape up a set of stock 92's with short cylinders and salvage enough parts to make 4 useable heads
Pictures will follow soon, going back outside now to start swapping engines, Hope to be running by tomorrow
