Ignition/Headlight Combo Switch
compunerdy
Post by compunerdy »
I just got done wiring and testing out a Durite 0-351-12 ignition/headlight switch. It took a bit of wiring to add the headlight circuit into it but it all works and the switch fits the stock ignition switch hole perfectly. You could use it just for a ignition switch if you wanted to.
I bought it off Ebay from this seller for $60.
http://www.ebay.com/itm/360643263022?it ... m=&vxp=mtr
Here is the brochure from Durite with the wiring schematic
http://www.durite.co.uk/pdf/2012/3/03.1 ... ntrols.pdf
I have it wired like this..
P= Parking lights
0= OFF
1= Ignition
2= Ignition + Parking lights
3= Ignition + Parking Lights + Headlights
4= I still have available for something else.. It would be Ignition + Parking Lights + ??? (Headlights including Offroad lights maybe) OR you could use this for your blackout lights possibly
Tim
1975 710K
