USB ports for Cell, GPS, Etc charging
Posted: Thu Aug 15, 2013 12:02 am
by compunerdy
I found this for USB ports that will run off 24V. The description says 12-24v input and so does the pictures but the package only says 12v. I have it hooked up and its working at 24v so not sure what is up with the packaging.
http://www.amazon.com/dp/B0082CXEI8/ref ... 25410_item
I am going to mount mine in the hole the hand push washer pump was in since I changed mine to electric but that would not work for most as I think it would hit the stock headlight switch.
Re: USB ports for Cell, GPS, Etc charging
Posted: Fri Aug 16, 2013 4:24 am
by VinceAtReal4x4s
Very nice find. Thanks for posting... seems like I have at least 3 things that charge off of usb now.
Posted: Fri Sep 20, 2013 12:58 pm
by Jack Russell Racing
I just spoke with the vendor (Blue Sea Systems), and their technical service rep informs me the socket from Amazon (which I just purchased
) is
not 24v compatible.
Posted: Fri Sep 20, 2013 1:06 pm
Jack Russell Racing wrote:I just spoke with the vendor (Blue Sea Systems), and their technical service rep informs me the socket from Amazon (which I just purchased
) is
not 24v compatible.
So they put 12v-24v right on the product by accident??
Posted: Fri Sep 20, 2013 1:30 pm
by compunerdy
I tested it for hours at 24v and it worked fine and mine does not say 24v on it.
Posted: Fri Sep 20, 2013 2:04 pm
Believe me, I want it to work too.. I just got it from Amazon and was planning to install in the same washer-pump location. Here is a picture of what I got, when purchased with the link provided earlier in the thread:
Posted: Fri Sep 20, 2013 10:53 pm
I run my USB off the 12V converter. Never thought to try to run it off 24V. I take the 24V off the radio plug behind the co-driver seat for the converter.
The devices will run off 120 or 240 for the chargers. Check the manual and it also shows on the little tag that also shows the model number.
