12 volt 712 -carby solenoids? any ideas
Posted: Thu Oct 03, 2013 11:23 pm
Hello, my name is warren this is my first post I am from Melbourne Australia and have only been a pinz owner for less than a year.
I bought my pinz already converted to 12 volts only the carb solenoids are still the original 24v they do work with a 12v supply however they are a little lazy or slow to open, it runs very well as all 4 do open but I am not happy with this as they will close if you tilt them on an angle where the spade terminal is only slightly higher than the nozzle.
These solenoids are easily found in 12 volt they came out in many early VW, Porsch,solex carbs among others only the size of the 3 holes in the nozzle end are available in 52.5 and 55(approx 1mm) the pinz 24v solenoid is 250(approx 3mm) hole and there is a big difference between them. I hope that was clear enough.
I am wondering whether to try the 12v solenoids as is or should i drill them. Will using them as is lean out fuel mixture dangerously. Has anyone out there come across this issue. I have spoken to a couple of people down here in carb workshops but none are familiar with this carb and therefore reserve their opinions, I have noticed there are some on this forum who have a very good understanding of these carbs (Jim and Scott) and I would really value their opinion.
Thanks Warren
Thanks Warren
