Clutch Master Cylinder
Posted: Sun Oct 20, 2013 7:16 pm
by blackstack
How does one access the front end of the clutch master cylinder to remove the unit for rebuild? Does something else have to be disassembled ?
Re: Clutch Master Cylinder
Posted: Sun Oct 20, 2013 7:27 pm
You have to reach up above the pedals into the pedal block assembly and remove the retaining clip and pin that connects the clutch master cylinder piston shaft (#10 in diagram) to the clutch pedal. It sounds more difficult than it is. I've replaced one once but it was a while ago and I don't recall any special techniques were needed.
Posted: Sun Oct 20, 2013 9:26 pm
Incorrect!!! Pull the 2 13 mm nuts and the line, tap the clutch master and it comes right out, pin stays on pedal assembly
Posted: Sun Oct 20, 2013 11:21 pm
Yup - Jim's right. Sorry about that, I forgot how simple it was. And Jim was the one who told me how to do it years ago.
Posted: Mon Oct 21, 2013 9:23 am
by blackstack
And I was thinking my hand was just too big and trying to convince the wife to stick her hand up there!!
Thanks you both for your answers (especially Jim )
