Float level gauge dimensions
Posted: Sat Dec 07, 2013 9:49 am
by blackstack
On this drawing http://s277.photobucket.com/user/richar ... l.png.html Should not the "critical" dimension be measured from the BOTTOM of the horizontal leg of the tool?
Does anyone know the measure of the "green window"? ie the separation between upper and lower limits?
Re: Float level gauge dimensions
Posted: Sat Dec 07, 2013 10:32 am
by Stekay
Posted: Sat Dec 07, 2013 10:51 am
by blackstack
Thanks for the link.. 1.05 " converts to 26.67 mm ...and that throws another number in the mix !!
I wonder if the 1.05 number is the upper limit level?? If that is the case the "green window" is .6 mm ..Correct?
anyone?
PS I fixed the link
Posted: Sat Dec 07, 2013 11:51 am
by Stekay
no i think they're just measuring from the top of the screw boss as opposed to the top of the gasket.
