Part needed
Posted: Thu Jan 23, 2014 9:24 pm
by pinzinator
Does anyone know where I can acquire this part, possibly in quantity? It is the part at the bottom of the Bosch distributor shaft for the Pinzgauer. Please PM me with info, much appreciated.
Re: Part needed
Posted: Thu Jan 23, 2014 10:04 pm
by Haf-e
Probably will need to get it machined up.... doesn't look too difficult. You might contact "compunerdy" and he gets a lot of parts machined up for his business at a good price.
Re: Part needed
Posted: Fri Jan 24, 2014 9:07 pm
by Middlebury_Pinz
Have you checked to see if a VW distributor drive off an air cooled type 1 engine will work? It looks identical. I'll check to see if I have one if you want it? Very common and easy to locate if it will work.
Re: Part needed
Posted: Sat Jan 25, 2014 12:42 pm
by pinzinator
Thanks everyone for your help! I have received enough replies to get the parts I need.
Re: Part needed
Posted: Sat Jan 25, 2014 2:02 pm
So your having it machined or a VW part works?
Re: Part needed
Posted: Sat Jan 25, 2014 3:55 pm
by pinzinator
Several sources including machining. Not sure if the VW part would work, but it should. One guy had 7 for sale, that helped!
