Fuel flow problem?
Posted: Sun Feb 16, 2014 5:17 pm
by thedoeges
Hello,
Here is another problem that just came up. When driving in higher RPMs the engine occasionally throttles back, as if on a governor, or starving. If I just kept the gas pedal pressed, it would consistently reduce RPM and with that, speed as well. Once I am standing at idle, which runs just fine, I can drive for a while before the problem occurs again. It has gotten progressively worse during the last two days. Iginition system is OK, new fuel filter inside glass dome, valves/compression just checked. Looking at the glass dome of my fuel strainer/regulator, it appears that the bottom half inch is always filed with fuel, yet I am not sure if that's enough. The engine ran good before and there was never a fuel regulator adjustment necessary. Maybe its the pump, but I would think that the pump would just give in and wouldn't be intermittent.
Any ideas?
Thanks.
Marcus
Re: Fuel flow problem?
Posted: Sun Feb 16, 2014 9:29 pm
Just a shot in the dark, what comes to mind is a clogged fuel cap vent.
Posted: Mon Feb 17, 2014 4:20 am
by roobar_and_custard
Or blocked fuel filter?
Posted: Mon Feb 17, 2014 7:28 am
by Uli-RT
...have you already changed the Filter near the Tank ?
And there is a strainer in the fuelpump.
Posted: Mon Feb 17, 2014 8:48 am
by thedoeges
I didn't know that there is a filter near the tank. The strainer is clean and new. Where is the other filter?
Posted: Mon Feb 17, 2014 9:48 am
by EmbarkChief
Has you tank been re-lined? My liner started peeling off and it plugged my pickup tube with a piece the size of a leaf.
Posted: Mon Feb 17, 2014 10:01 am
by thedoeges
I will check it out. Don't think it was relined.
Posted: Mon Feb 17, 2014 3:13 pm
by EmbarkChief
Fuel Tank DeLamination viewtopic.php?t=8614
Posted: Mon Feb 17, 2014 6:13 pm
by mopar
That is a problem with Pinzgauers never heard of it with a volvo.
Posted: Mon Feb 17, 2014 6:46 pm
by thedoeges
I checked the filter and there are no particles caught. I also blew out the fuel filler neck vent tube, there was dirt in it, and increased the fuel pressure on the Filterking pressure regulator. He's running great so far, but if the problem comes up again, I will check the tank, fuel lines, and maybe even the fuel pump. Just don't think it's anything mechanical, as the truck has only 23000 original miles on it, and everything else works like a charm.
Posted: Mon Feb 17, 2014 9:12 pm
by EmbarkChief
Oh snap, I'm so sorry! I wasn't paying attention to the sub forum from my mobile. Disregard :-(
