Cooking without fire, gas or electricity
Posted: Tue Mar 04, 2014 8:34 am
I might give this a try to see if it actually works!
http://www.youtube.com/watch?v=zRZyDbbwDTw#t=241
Re: Cooking without fire, gas or electricity
Posted: Tue Mar 04, 2014 9:26 am
Looks like the same stuff that heats MRE's. Didn't see anything about cost, did I miss it?
Posted: Tue Mar 04, 2014 10:24 am
yeah I would guess it is the same
I did not see cost but did find this one online:
$25 includes the kit and 10 heat pods
http://www.amazon.com/dp/B00CJCXC16//re ... elprods-20
Perhaps army surplus is even cheaper?
Posted: Tue Mar 04, 2014 10:38 am
Looks to be a great thing to add to the bug-out bag or for the emergency prep kit for your house or car.
Posted: Tue Mar 04, 2014 4:27 pm
by 4x4Pinz
been in Arizona too long. All I could think of was "so what it is called solar cooking" Then to find out that it is the chemical reaction causing the heat.
Posted: Wed Mar 05, 2014 11:38 am
by McCall Pinz
Hmmmm. Has anyone tried any "manifold" cooking with a Pinz? If the heat exchanger could open up, you could put some burritos inside!
Posted: Wed Mar 05, 2014 12:02 pm
Now there is an idea for some fabricator to capitalize on. Should probably be made out of stainless for easy clean-up.
Posted: Wed Mar 05, 2014 12:47 pm
by westernair
Cooking on the engine is a skill I learned in the army. We would use the top of motor on a 113 personnel carrier.
The hot pouches that are plug into the 24 accessory plug that was designed for MREs also is a great way to cook in your truck. They are realitvly cheap on the surplus sites.
Posted: Wed Mar 05, 2014 12:54 pm
The pouches will require a plug modification to work in a pinz, I believe. Mine did.
Posted: Sat Mar 08, 2014 1:33 pm
by Dreadnought
I was chatting to a Russian trucker way back in the 70's......he had a stainless steel box with a lid which clamped onto his exhaust pipe up near the engine.....It would cook stew, pies in fact anything that could be fitted into the box.
