Rotted hose
Posted: Thu Mar 13, 2014 10:13 am
by Jack Russell Racing
Does this explain why I've had an exceptionally cold winter in my Pinzguaer, or does it explain why I'm feeling light-headed after a short drive? Easy to swap out?
(just kidding, I'm not feeling light headed)
Re: Rotted hose
Posted: Thu Mar 13, 2014 10:25 am
No - that extra outlet is for the pre-heater
viewtopic.php?f=9&t=8609&hilit=heat
You were cold because:
1. Pinz heater is a joke
2. Pinz is a soft top
3. Seems like the coldest winter in years
Re: Rotted hose
Posted: Thu Mar 13, 2014 10:40 am
by pcolette
Yup - easy to swap out. Here's the part number: 7122190128/N plus 2 clamps if needed.
Re: Rotted hose
Posted: Thu Mar 13, 2014 10:45 am
by edzz
TechMOGogy wrote:No - that extra outlet is for the pre-heater
Yes it helps to explain lack of heat as i suspect that instead of the pre-heater outlet "outputting" hot air to the engine intake, cold air was being sucked in and passed to the cab heat hose.
4. lack of electrically heated clothing
viewtopic.php?f=17&t=8735&hilit=electric
Re: Rotted hose
Posted: Thu Mar 13, 2014 10:46 am
How does the pre-warmer affect his warmth in the cab?
Did I miss something?
Re: Rotted hose
Posted: Thu Mar 13, 2014 10:48 am
by krick3tt
Years ago I wrapped my hoses to the cap with insulation...improves the heat transfer to the cab tremendously.
Re: Rotted hose
Posted: Thu Mar 13, 2014 10:53 am
I'll get a replacement ordered today. Looks to be cheap as chips.
In the meantime, I just cut it cleanly and reattached it with the existing band clamp out in our parking lot. I've sent a coworker out to pick up some lunch in the Pinz, and he'll report back shortly on whether it is any warmer. Outside temps today are < 40dF.
Re: Rotted hose
Posted: Thu Mar 13, 2014 10:54 am
by edzz
TechMOGogy wrote:How does the pre-warmer affect his warmth in the cab?
Could be
edzz wrote: as i suspect that instead of the pre-heater outlet "outputting" hot air to the engine intake, cold air was being sucked in and passed to the cab heat hose.
Re: Rotted hose
Posted: Thu Mar 13, 2014 10:57 am
by edzz
Jack Russell Racing wrote:I'll get a replacement ordered today. Looks to be cheap as chips.
Probably wouldn't notice much distance if its a relatively short trip.
Re: Rotted hose
Posted: Fri Mar 14, 2014 11:20 am
Here's the update: Massive difference in heating! Seems like within 2 minutes of engine start, there is HOT air coming from the vents. Almost warm enough to roast a marshmallow -- and certainly warm enough that gloves and a jacket are no longer needed. Thermal expansion of the windscreen glass and dashboard instruments are a serious possibility.
Actually, its still stone cold.
But at least my hose isn't flopping in the wind.
