Grounding.
Posted: Thu Mar 13, 2014 11:05 pm
by JimmyC
Which pole of the batteries is typically grounded?
Re: Grounding.
Posted: Fri Mar 14, 2014 12:10 am
by edzz
JimmyC wrote:Which pole of the batteries is typically grounded?
Pinzgauers are negative ground.
Remember the battery cutoff switch interrupts the ground circuit. if you ground any thing directly to the battery you are potentially defeating the system. there is also a relay in the cutoff circuit that is intended to temporarily maintain the circuit in the event the battery cutoff switch is switched off when the engine is still running to prevent alternator damage.
Did any of that make sense? :?
Re: Grounding.
Posted: Fri Mar 14, 2014 10:48 am
by compunerdy
Well to answer your question directly.. the negative pole is grounded lol
Re: Grounding.
Posted: Fri Mar 14, 2014 2:42 pm
by edzz
compunerdy wrote:Well to answer your question directly.. the negative pole is grounded lol
Yes negative is grounded, however not by a single ground strap directly to the chassis as would be done with most vehicles.
Re: Grounding.
Posted: Fri Mar 14, 2014 3:58 pm
by compunerdy
It is on mine.. but that is because I redid my wiring.
Re: Grounding.
Posted: Sun Mar 16, 2014 11:25 am
by Haf-e
Actually only the negative post of one battery is grounded - its a 24vdc system.
