Leaks - front differential and portal
Posted: Tue Jun 03, 2014 11:29 pm
My pinz has been sitting a while and I'd like to get it in shape for Treffen this year. Historically I haven't done much of my own maintenance, but I'm in a position to finally start learning.
She's leaking in several spots and I'm hoping that at least some of these repairs I can make on my own, but I need a little guidance.
The first one is probably simple and obvious. I think I just need a new oil pan gasket. There's quite a bit of wet oil on the bolts near the rear of the pan.
The next is the portal. Only the front passenger is leaking. I've had blown portal seals in the past, but I'm not sure this is the same problem. Is it easy to determine what would most likely cause a leak around the hub like this?
Finally, there's a pretty regular drip from the area on and around the front differential. I have double checked tightness of the drain plug and it seems tight. Any advice on how I could narrow this down to something more specific or a particular area?
I really appreciate the help.
Brett
Brett
