712 brake bleeding/adjusting problems
Posted: Fri Jun 20, 2014 5:38 pm
I'm new to the forum, I signed up a couple months back because a guy across the street from my shop has 2 710's and a 712 that he runs a scenic tour business from. I've done some maintainence on them, full fluid change, boot swaps, etc. mainly with the help of you guys on this site. Thanks a bunch!!
I've run into a problem that I can't figure out on the 6 wheeler tho... He acquired it this spring and it had a pulling left issue when braking. I adjusted the shoes the way I have always done (inspected them as well and all were looking good) and it made the situation better, but never totally took it away. Now the problem is back with a vengeance... On a gravel road, at about 20mph I can stand on the brakes and lock up all 3 wheels on driver side, but passenger side only pushes a small amount of gravel with center axle. I cannot get the front passenger to lock up no matter what I do..
I have so far;
Bled that side of the vehicle 17 or so times, doing it the way I always have, the way the book says, the way some guy did when I was a kid... I even built a pressure bleeder to reverse bleed, pulling excess out of the master for 4 full cycles on each of the right wheels. No change..
I changed the pads and rotor on front right to a new set the owner had ordered. Seemingly when they were ordered the owner was told that they were all built as matched sets and not to mix up pads with rotors because they wouldn't work correctly. Never heard this before, but I followed what he said. No change..
Replaced the wheel cylinders on front right, then power bled again. No change..
Readjusted the pads to the book numerous times to no avail. I can't keep this thing from wanting jerk itself right off the road under hard breaking. Pulling my hair out here..
If anyone has some other suggestions please let me know. It's turning into busy season here for his tour business and I need to get this working safely as soon as possible...
Brad
I have so far;
Brad
