What do I call this cover/gasket?
Posted: Wed Jun 25, 2014 9:01 am
by Pinz710m2
As you can see in the last photo, I've got a leaky gasket/cover.
I'm not really sure what to call this, or what it covers, but I need
to order another from EI or SAV. What do I tell them it is? As you
can see, it has 2 screws holding it on, with 2 bent washers retaining
the screws from turning.
(Pics are in order as you get closer, so you can see where it is)
Re: What do I call this cover/gasket?
Posted: Wed Jun 25, 2014 11:29 am
02-50-55
GASKET TRANSFER CASE ZF 4104306010 7101245671/ 02-50-55 7.60
http://www.pinzgauer.com/parts.php?cat= ... view=02-50
or get some gasket material and make one.
so easy a four year old could do it.
Posted: Wed Jun 25, 2014 1:05 pm
by Pinz710m2
Thank you. Ordered.
I must have looked at that diagram a dozen times and never saw it.
Posted: Wed Jun 25, 2014 7:18 pm
by Buzz
You will find there are a number of great gasket making products out there. I have had great results with Right Stuff for valve covers and wheel hubs. I learned about it on this board. The point is that you don't always have to sweat ordering a gasket. For me, the time saved can be a big advantage.
Posted: Mon Oct 27, 2014 10:48 am
by dadnova
Like said prior, making gaskets is easy if it's a simple pattern, been doing it for 40 years.
There are several types of material depending on you gasket needs.
Thin, thicker, thick, cork and so on. A little gasket cinch and done, again depending on your gasket needs.
