I just picked up a 710 and i have been fixing it up for the past couple months since i got it. I have a couple cracks that i would like to repair on the service cover on top of the engine cover. I did some searching and found 1 post mentioning fiberglass. Ive tried JB weld, no luck , a flexable plastic adhesive from loctite, no luck and a 2 part epoxy i use at work....no luck. Im not too concerned on what it looks like because i am going to be coating it with a bedliner i just dont want it to recrack or get worse after i bedline it.
If fiberglass is the way to go then thats what ill do but i wanted to see if anyone has any suggestions.
Thanks.
Engine Cover Repair
Re: Engine Cover Repair
Post a picture, that would help us give you better advice.
What ever you use it needs to be flexible to a degree as the original material is a little flexible.
My first thought would be SEM Brand Flexible Sem-Weld Product# 39927, It is a two part adhesive that remains flexible after curing.
Miles
Miles
'73 Pinzgauer 712M
'73 Pinzgauer 712M
This would do the trick
Expensive depending on your cracks but perhaps craigslist or eBay has a used one?
http://www.eastwood.com/eastwood-s-hot- ... ystem.html
Much cheaper than a new engine cover.
First, drill a small (1/32" dia) hole at the end of the crack so that it doesn't continue to run. I repaired a crack in my engine cover (running from the edge inward about 2") by saturating a piece of 1" wide kevlar webbing with JB Weld and clamping it against the underside of the cover along the crack for 24 hours. I precleaned the repair area with acetone. I initially tried to fill the crack from the top side with JB Weld, but it made a bit of a mess and quickly failed. The key was the thin webbing material. You could most likely use a strip of cotton canvas or Cordura nylon to achieve the same reinforcement.
George Cameron
Yarnell, AZ
1979 Pinz 710M
Molon Labe
Yarnell, AZ
1979 Pinz 710M
Molon Labe
