Stainless steel lug nuts
Posted: Mon Jul 07, 2014 9:58 am
by ziegler
I've been trying to find s.s. lugs for the pinz that are about 2 inches long with ball seat. I will use them for a step to aid in getting in and out of the truck. The 2 inch lugs make a good step and do not stick out beyond the outer aspect of the tire like the hub steps do. I believe the thread pitch dimensions are 1/2-20. If anyone knows of a custom fab shop, I'd appreciate it. Zig
Re: Stainless steel lug nuts
Posted: Mon Jul 07, 2014 11:13 am
if the hub steps stick out farther than you want cut them off. I would not put on extended lug nuts out of fear of barking them on rocks. Easier to make your own hubsteps (and probably cheaper) than to install lug nuts that may noy function as well as the stock lug nuts.
Posted: Mon Jul 07, 2014 11:31 am
These are made from 1 1/2 inch floor flange and 1 1/2 inch x 12 inch nipple cut in two. Hole drilled through to spin off with philips screwdriver and mesh welded for grip.
Parts from HomeDepot and cost is less then $12. The flange fits perfectly between the wheel and the hub in the 1/4 inch space available.
Posted: Wed Jul 09, 2014 7:28 am
I built a similar set of hub steps; please note that the pipe flanges that I got were thicker than the pocket in the drum. I had to turn them thinner in a lathe to ensure that the rims fit tight against the drum, and the drum is held tight to the hub. If you use thicker pipe flanges then the drums will be loose and this will effect the braking consistency and could cause the brakes to lock. A too-thick pipe flange might crack the wheels as well.
Thinner pipe flanges will rattle within the space between the wheel and the hub. Use a piece of rubber to keep it snug and prevent rattling.
While rolling your own steps is great, make certain that you do so safely.
Posted: Wed Jul 09, 2014 8:12 am
Jim,
Thanks for the words of caution. They are well received and I did a lot of searching and measuring before fitting the flanges.
I am confident that all is well. I have used them for about six years now, they work well and are a boon to getting in, especially for the passenger.
Posted: Wed Jul 09, 2014 6:41 pm
Hi Morris,
I was not attempting to critique your hub steps :oops: , I was trying to ensure that anyone else who was contemplating making their own hub steps know about the possible pitfalls. I consider you to be one of the more competent posters here! 8)
Posted: Wed Jul 09, 2014 9:22 pm
Jim,
I knew that,
I was just reinforcing the idea that research needs to be well done if anyone is attempting to put something not designed for the vehicle on it. Especially in a place that could cause damage
and possible loss far exceeding expectations. I have seen pics of vehicles losing a wheel and the ensuing damage.
Thanks for your kind words.
Posted: Wed Jul 09, 2014 10:43 pm
by Pinz710m2
It just dawned on me ... go to the Gorilla Nut home page.
Gorilla lists every product they make with exact dimensions.
They have a very comprehensive product line with all kinds of
lugnuts and all types of seats, shafts, threads, etc.
http://www.gorilla-auto.com
... besides, you can tell people you have Gorilla nuts on your truck.
Posted: Wed Jul 09, 2014 11:23 pm
Look at Scott's Post about lug nuts.
viewtopic.php?f=15&t=8253&p=60278&hilit=lug+nuts#p60278
Posted: Mon Oct 13, 2014 12:08 pm
by GenevaPinz
Please be careful with one thing about Pinz lug nuts: they have a M14 x 1.5 thread, which is a "fine thread", i.e. NOT the standard M14 thread (the standard is M14 x 2.0, which is usually just called "M14").
I did some extensive googling a few years ago to find flat-based lug nuts that would fit my Ford Transit wheels. I managed to find some eventually in Germany, but only in a box of 100. So I enough spares now... :mrgreen:
Posted: Mon Oct 13, 2014 12:13 pm
by GenevaPinz
Ok, right after the above post I decided to look for M14 x 1.5 lug nuts and expected to find close to nothing, and it turns out Summit Racing has about 160 items that match this, first line of the google search results :shock: ... I guess in my time the flat base was the issue... anyway, good luck in your search! Keep us posted on the results.
Posted: Tue Oct 14, 2014 7:45 am
by Haf-e
Hey Geneva - can you post a picture of your transit rims? how is the offset?
I was considering having some custom lug nuts made up at one time in stainless steel - but mostly to allow switching to a larger lug wrench size - the stock ones look kinda small - guess I just thought my truck needed to have some bigger nuts...
Posted: Thu Oct 16, 2014 3:10 am
by GenevaPinz
Haf-e wrote:Hey Geneva - can you post a picture of your transit rims? how is the offset?
Here are my transit rims:
...and the offset, a bit less than one inch compared to stock. The rub rails (not installed on the pictures) extend further out a bit. Tires are Cooper Discoverer STTs in 265/75-R16:
...and finally, the tags that were on the rims when I purchased them:
I believe "4 138 552" is the Ford part number.
Posted: Thu Oct 16, 2014 10:40 am
by cascade.king
Fyi- I just ran that tag in the Ford system. The part IS 4138552, engineering # is YC151007DE.
Also, this wheel is not part of the FOMOCO USA parts stream. I'm told the Ford 16 x 6 1/2 USA part# is YC151007DA.
List price $258.82.
Posted: Thu Oct 16, 2014 2:05 pm
by Haf-e
Those Transit rims are different looking than the new 2015 Ford Transit just showing up at ford dealers here in NA - but I suspect the backspacing and such is the same - slightly more offset to the outside. The newer rims have a smoother center area and ten holes in the outside rather than the five slots on yours. I posted a pic in another thread with photos.
Hadn't thought about the issue of what lug nuts would work with them - good to hear that there are some options out there.
I know on my sprinter van that people would upgrade to the aluminum factory wheels and offer their old steel rims off for cheap - so I am hoping that will happen with the new Ford Transits as well - making a source of cheap rims available to the USA older pinz owners... Some of the RV converters swap the steels to aluminum on every rig they convert - so elkhardt indianna might be a good place to check... although they now just sell a lot of the parts off on ebay...
