Mark
Is brake fluid flammable? I thought it was not, especially considering the hygroscopic characteristics of most DOT formulas.Brickren wrote:I was thinking about under the dash as another fire prone area. Especialy since all the brake fluid under there.
TechMOGogy wrote:Can you list all the stuff you have in the pictures - some stuff I can't tell what it is
Dr-Nuts wrote:That's a halon fire suppression system and if there was a fire it would go off on its own and there is also a guarded pull knob in the dash hooked via a cable to the unit. If the fire was inside the doghouse you could lift the top cover and pull the knob to activate the system. Should put out most fires. Way over kill but what the hell. Even has a 24 watt 110volt red CFL bulb in a explosion proof housing that is really cool at night for those "RIG FOR RED" moments LOL
Mark
I disagree.NoahDL88 wrote: That halon stuff is nasty, seems not only overkill but downright unsafe and irresponsible, I don't know many bilge rats that can climb out of the engine space once that systems been activated.
Jack Russell Racing wrote:I disagree.NoahDL88 wrote: That halon stuff is nasty, seems not only overkill but downright unsafe and irresponsible, I don't know many bilge rats that can climb out of the engine space once that systems been activated.
We spec Halon 1211 in all Ferrari/Lamborghini applications that we deal with. It works well and leaves zero residue. It has only been banned by the EPA for ozone-depletion -- but I bet a burning Pinzguaer does more harm to Mother Earth than the deployment of 5# of Halon 1211.
I sit corrected (and surprised). From what I've just read, many automotive fluids that we think are inflammable actually burn at the right temps:Brickren wrote: Also ,brake fluid is very flammable. Ask a fireman.
