Parking brake disc replacement. Has anyone done it?
Posted: Wed Aug 27, 2014 1:56 pm
by Twin Pinzies
I'm about to redo my parking brake. Is it a total P.I.T.A. to get at the disc? Do I need any special tools for disassembly or gaskets for reassembly?
Thanks in advance guys and gals for any insights!
Re: Parking brake disc replacement. Has anyone done it?
Posted: Wed Aug 27, 2014 3:45 pm
I took mine apart to examine them and it was only an issue when I had to lift the body to pull the assembly apart.
Send me a PM and I can send you the photos I took at the stages of removal. Include your email for the photos.
Only special tool was a big 'C' clamp to tighten the body back down.
Posted: Thu Aug 28, 2014 12:37 pm
by berger
Perhaps you could document the work and add it to the tech sessions.....
Posted: Thu Aug 28, 2014 1:06 pm
You'd do best to check the parts manual as to whatever part/s may be needed. I don't recall any gaskets there, as it's rear of the differential and not sealed IIRC. Best to double check on your own though.
From memory, it's not too big of a job. There was one top body mount that was a real sob to get. But other than that, I don't recall any particular troubles.
BTW, don't forget the required twist to the brake cable when you reinstall it, or the brake won't lock properly.
Posted: Thu Aug 28, 2014 1:27 pm
I sent Herb photos of my teardown. I am not any kind of expert on pinzgauers but I thought some shots of the internals might help him out.
If anyone wants to see the photos PM me your email and I can send you what I sent to him.
If he wants to post any of the photos it would be fine, I have real problems getting my photos to post properly. I also suggested the manual for reference. There are no gaskets.
