air powered oil pumps? and recommendations?
Maybe one that clamps on a 5 gallon bucket? I'm really hating the little red pump.
I need it for 3 different oils so it would be nice to have one that cleans or transfers well.
Any recommendations?
Re: air powered oil pumps? and recommendations?
I use a 5 gallon tank made for refilling oils from Longacre racing. Has a gauge to tell what pressure you have in tank (tank pressurized by means of an air compressor) and a 2" fill port to add oil as needed. I changed the fill hose to a 6' hose to make filling the pinz easier as it came with a 3' hose. If I felt the need for multiple oils I would simply acquire as many as needed. These are very handy and make changing/adding oils very easy.
I saw your post on it a while back - cant seem to find that piece on Longacre or ebay. It would be perfect!
Maybe a Samson 1320 ? Kind of pricey but is this what you have in mind?
Available at tooldiscounter.com
There's one on eBay right now - http://www.ebay.com/itm/141367012213?_t ... EBIDX%3AIT
Perfect!! Purchased!!
Thanks!!
I wanted to report back for anyone who seeks something similar in the future: this item is simply fantastic! I swapped out all of the fluids in the truck yesterday (minus brake fluid) in 2.5 hours, with very little mess. It was on crushed stone, so ingress/egress was uncomfortable. I'm sure I could do it in half the time in the future.
I poured a 5 gallon bucket gear oil into the tank, and almost emptied it by the time I was done. No more pump action fluid transfer for me, now that I have a device to do it for me! :wink:
I know once I got mine it made topping off and changing oils a breeze. I used to change all the fluids in my trucks two to three times a year (put a lot of time offroad in my trucks). Without a doubt it is one of the best "mods" you can get for the pinz if you use it and maintain it regularly.
GRCameron
Post by GRCameron »
This looks like an economical solution. For the price you could have several of them - $149.99
The Samson 1320 retails for about twice that. The ebay item was a GOOD DEAL!
http://www.northerntool.com/shop/tools/ ... _200622686
George Cameron
Yarnell, AZ
1979 Pinz 710M
Molon Labe
Nice find! I would have purchased that in a second had i not been told of the ebay buy. REALLY recommend having one of these, if not two!
