Mass Air Flow Sensor -- cleaning
Posted: Wed Dec 31, 2014 4:19 pm
by rmel
If your Pinz has the fuel injection and ECU upgrade, and includes as Mass Air Flow sensor
you may want to invest in a can of Mass Air Flow cleaner and Throttle body cleaner.
I had my doubts this would do much of anything. However after cleaning the MAF sensor, I
was pleasantly surprised how much smoother idle is, a boost in RPM, and more consistent
AFR readings. Makes sense, the MAF is eating all the trail dust before it gets to the air filter.
A new checkoff item with every Oil change.
ron
Re: Mass Air Flow Sensor -- cleaning
Posted: Wed Dec 31, 2014 7:49 pm
by GRCameron
Shouldn't the MAF be located after the air filter as in most vehicles? It seems odd that it is placed before it. Most EFI vehicles have it placed 3-4 inches upstream of the throttle body.
Posted: Thu Jan 01, 2015 12:36 pm
by rmel
Yes, ideally the MAF would be down stream from the air filter.
To do that for those who do have this conversion and run with the stock Pinz A/F
the MAF is located at the throat of the air intake -- no other place to put it. Not
the ideal location, though this has been the 1'st time I ever cleaned this sensor,
and it's been only this last year that idle has been rough. I think I can live with this
with an occasional dusting and cleaning at each oil change :wink:
