710/712 steering column/shaft pictures/info?
Posted: Wed Jan 21, 2015 2:51 pm
Does anyone have any info on the steering shaft for at 71* series Pinz?
Trying to find if shaft is round, D or double D shape?
Any info helpful
Re: 710/712 steering column/shaft pictures/info?
Posted: Wed Jan 21, 2015 5:23 pm
Check the photos I put in the Tech section when I rebuilt my 712 steering box, see if your questions are answered.
Posted: Wed Jan 21, 2015 5:50 pm
by Stekay
PM me your email and I'll send you the manual. Looks round
Posted: Wed Jan 21, 2015 7:30 pm
If you are talking about the shaft that the steering wheel attaches to, it is a one piece round shaft with the splines for the wheel at the top and the worm gear at the bottom, complete with ground-in ball races for the bearings. The splines for the wheel do not have any index (a missing or wider spline), the wheel can be put on in any orientation. I did not take any dimensions when I had mine apart, sorry.
Posted: Wed Jan 21, 2015 7:54 pm
Jimm391730 wrote:If you are talking about the shaft that the steering wheel attaches to, it is a one piece round shaft with the splines for the wheel at the top and the worm gear at the bottom, complete with ground-in ball races for the bearings. The splines for the wheel do not have any index (a missing or wider spline), the wheel can be put on in any orientation. I did not take any dimensions when I had mine apart, sorry.
Thanks!
