Battery Switch - replacement specs
Posted: Mon Mar 30, 2015 2:38 am
by ako
My Pinz came without the battery switch, I guess they took all the expensive elec bits for spare parts before they decommissioned it.
I have holes in the floor behind the drivers seat.
Does anyone have the specs for a replacement unit, such as the maximum volt and amp rating? I would rather buy an equivalent locally rather than pay air freight.
This is the part I mean :
http://www.pinzgauer.com/showdetails.ph ... 111850180/
Mick
Re: Battery Switch - replacement specs
Posted: Mon Mar 30, 2015 4:36 pm
Posted: Tue Mar 31, 2015 2:59 am
by ako
Thanks, but I guess you missed this bit :
ako wrote: I would rather buy an equivalent locally rather than pay air freight.
I pay $10 US / pound for getting stuff here.
I went to a truck parts store and asked for the most heavy duty battery isolator they have. I bought a Electro Mecanica Cormar P/N #5000010 which is rated to 250A continuous or 2500A for 5 seconds. Should do the trick.
It was $37 locally, rather than the $49.50 plus freight (and 2 weeks delay) from SAV.
Posted: Tue Mar 31, 2015 11:53 am
by David Dunn
If readily available where you are, Hella has a couple of disconnect switches.
http://www.hellamarine.com/en/products/ ... -switches/
In reality, you don't have to have them. It is a "military " thing to keep batteries from dying from parasitic draws from time of infrequent use or storage
FYI. On the gas Pinz, they were on the negative side of the battery, and on the TDs on the positive.
Do you still have the relay that keeps the circuit closed while the truck is running ? ( It's in case some fool turns the switch off
Posted: Tue Mar 31, 2015 12:04 pm
by ako
Hi David.
Yes, the relay is still there. It seems they simply removed the isolator and joined the negative straps together.
Since my new lever is removable, I think I will use it as a 'key' to help prevent some dirt bag try to drive off in my truck.
Posted: Tue Mar 31, 2015 12:42 pm
by David Dunn
ako wrote:Hi David.
The old ones were removable too.
That's what most of us do... that average moron sometimes have a problem when the ignition switch isn't in the steering column.
Posted: Sat Feb 20, 2016 9:08 pm
by sealan
ako wrote:My Pinz came without the battery switch, I guess they took all the expensive elec bits for spare parts before they decommissioned it.
Mick
- uploadfromtaptalk1456024076991.jpg (80.93 KiB) Viewed 5066 times
Thus is what i have left from my 718M
Sent from my SM-N9208 using Tapatalk
Posted: Sat Feb 27, 2016 12:09 pm
by ako
How is your parts finding mission going then?
