no brake light right side
Posted: Tue Apr 21, 2015 3:07 pm
Suddenly no right brake light. Very confusing. disassembled the internals for the tail light and cleaned terminals. Turn signals and flashers work (small bulb), regular tail light is dim on right. Replaced bulb. No change.
The connector box under the pinz has no numbers to follow to check circuit.
I'm lost on electrical stuff and seem to only be able to follow most obvious clues like frayed wire, or not connected to terminal replacing bulb and such.
Maddening search, any helpful clues?
edit: just checked...gas gage works
edit: unfortunately my owners manual shows a fuse box and not the breakers that I have. Is there an explanation for what breaker controls what electrical function? This is maddening ..day two.
