Front carb fuel fitting wanted
Posted: Sat Jun 13, 2015 6:21 pm
by pinzinator
I'm looking for the fuel fitting that feeds the front carb, the rubber fuel line connects to it. It is a single inlet banjo fitting, the rear is dual, since the rear carb feeds the front and rear together. If you have one available please PM me with a price.
Re: Front carb fuel fitting wanted
Posted: Sat Jun 13, 2015 10:01 pm
by GRCameron
You might find what you need at BelMetric.com. They have been prompt and their prices seem good. Here is a link:
https://www.belmetric.com/banjo-eye-fit ... bd3cs19ek7
Posted: Mon Jun 15, 2015 10:26 pm
by pinzinator
Thanks for the link! The banjo bolt is M12 X 1.25 so it was easy to find the one I needed.
Posted: Mon Jun 15, 2015 11:30 pm
by Garrycol
I recently had the same issue and could not find one anywhere - no auto parts places had them.
I then went to a diesel tuning specialist (Cooma Diesels here) and that had exactly what was required - threads were not an issue. They use them on their diesel connections for fuel pumps and filters etc so had a large range. The banjo and hollow bolt were relatively cheap so try your local diesel specialist.
