718 Wheel Options
718 Wheel Options
Hi Guys,
We found these relatively inexpensive wheels from the Dodge Sprinter Vans. The kicker was finding a Lug Bolt that would work with the new wheels as they have a conical seat versus the military ball seat and you cannot use the stock bolts. Anyways, replacement bolts came out of Italy and make it a bolt up conversion. Pictured is with 255/85R16 Maxxus Big Horns.
If anyone is looking for some extra combat wheels drop us a line and we have 15-20 spares!
Scott
Scott
- IMG_0592SM10.jpg (46.03 KiB) Viewed 4509 times
- IMG_0586SM4.jpg (68.23 KiB) Viewed 4509 times
- IMG_0585SM3.jpg (43.24 KiB) Viewed 4509 times
Vallejo, California
www.expedition-imports.com
Vallejo, California
Re: 718 Wheel Options
Do you have a pic of the mil wheels you have there? Wondering about fitting to a G... are they number 34 or 35 on this list? (6.5" or 7")
http://www.rubicon-trail.com/G-Class/wheels/start.html
vince I think these are the mil wheels he has.
- 718wheels.jpg (23.2 KiB) Viewed 4461 times
1974 712M AKA the Banana
1987 718M Now Sold
1975 Volvo TGB1111 Now Sold
1963 404S Now Sold
Hi Vince,
Mopar is correct, I have the Delta combat wheels which are incredibly heavy and pretty hack in terms of balance. Definitely not the G Hutchinsons.
However, if you are going to be taking gunfire and want to continue to drive, give me a call
Scott
Scott
Vallejo, California
Vallejo, California
Ah, I see, well those would look like ass on a G. Guess I'll hold off.
You might consider the stock steel rims from the 2002 to 2006 Sprinter T1N models - they are extremely similar to the #35 on that chart except they are 6.25" wide between the bead lips and have a 75mm ET so it might require some spacers depending on the model of Gwagen you have. Pretty easy to pick up in the USA for $50 each via wrecking yards or craigslist/ebay - just be careful as the 2007 and later models are 6 lug and there is also a dually rim which won't work.
I just did a quick search and found some "premium replacement" rims for sprinters that look like the stock ones but list the ET as being 55mm instead of the normal 75mm - that should make them work well on a 460 Gwagen. Its probably an error though.
http://www.getallparts.com/Dodge-Sprint ... fgodZj4GEA
They are only $78 each.
That would be cool. I need to avoid spacers. I'll have to check into those last ones more.
I actually have a number of these sprinter rims around my shop and can loan you one if that would help... let me know and I can put it in UPS for you.
Hey Vince - There is a thread on the Expedition Portal site of a guy who just bought a Gwagen and is planning on replacing his wheels - so his steel rims might be available. He is in Los Angeles.
http://www.expeditionportal.com/forum/t ... 300GD-w463
http://www.ozpinz.com
Hello Together,
I'm Steve from Sydney, I just bought myself a 718K P80 Pinzgauer and I'm new to the Pinzgauer.
Have had 2 Defenders but sold me tourer no replaced by the Pinz.
Just saw this thread and was wondering whether there is a list of wheels which fit from other
brands, I saw the Dodge ones but they will be hard to get here in Australia.
Any help would be greatly appreciated.
Steve
Steve
- LightRoom_catalouge_New-2.lrcat_-_Adobe_Photoshop_Lightroom_-_Library_2017-05-30_10-25-09.jpeg (477.58 KiB) Viewed 2859 times
The dodge is just a Merceded Sprinter re-branded here in the USA. You need the 5 lug type - so prior to 2007. The sprinters wheels are deep offset / high ET - possibly more than the stock Pinzgauer wheels - and they are only 6 inches wide - so it you want a wider wheel then look at aftermarket alloys for Sprinters - they also seem to have less ET / offset.
Looks like a nice truck! Welcome to the forum!
Same with ssangyoung rexton rims....ik have them on my 716k
off-road until i die
