Krawl gear kicks out unless i hold in gear. Adj tips?
- audiocontr
Anything i can do with the linkage to keep K from kicking out?
1978 GMC Palm Beach
2001 F250 Diesel and trailer
1978 GMC Palm Beach
Re: Krawl gear kicks out unless i hold in gear. Adj tips?
Make a mark on the adjustment disk near the gear leaver tower so you can always go back to what you currently have.
Put it in neutral.
Loosen the bolts.
Hold the gearbox side of the disc still.
Get someone to hold the gear lever all the way to right (looking forward from the back of the vehicle) in the neutral line.
Tighten the bolts.
Try that.
If that doesn't work, then watch the rod movement at the gearbox tower when it is put in Krawler. Leave the system in krawler and disconnect the bolts completely. The gear lever should jump back to neutral if the spring is working.
See if stays in Krawler.
Then you will know if it is a problem deeper in the gearbox or just an adjustment issue.
John
Put it in neutral.
Loosen the bolts.
Tighten the bolts.
Try that.
John
