When I was young we use to set the timing on cars by advancing them until the engine knocked under full load then backed it off just a bit, like 2 degrees. Then we tried to start it and if it cranked hard we backed it off a bit more. Has anybody tried this?
Does anybody understand why the static timing is different with a hot vs cold engine?
Does anybody use a timing light?
Ignition Timing
Ignition Timing
Jim Chance
710M
710M
Re: Ignition Timing
I have used a timing light powered from a seperate 12V battery I keep on hand. Usually 3-5 degrees BTDC worked well for me. Now that I have the PinzSSI system, timing is set without the engine running per the instructions.
Re: Ignition Timing
I have the SSI ignition, and lost the ability to use the timing gun. Therefore, I use the technique you described... advance until it knocks, the come down a little more...
Works...
Works...
Jerome
CRJ Driver
CRJ Driver
- audiocontr
Re: Ignition Timing
Agreed on SSI - i was able to advance a few more degrees than the SSI instructions state without issue.
Re: Ignition Timing
I am confused. I thought the SSI was statically set at TDC, red light on, and the SSI module did the rest. No need to adjust anything else. Am I missing something?
75 Swiss 710K
W9YG
W9YG
- audiocontr
Re: Ignition Timing
it is, but you can advance a little past TDC and not find yourself in a ping state. i found it idled and ran better
Re: Ignition Timing
in the early models the SSI had a switch for on road and off road. you could advance it manually a little. not many used the option and it just made the system a little more complicated for little gain. I just run mine slightly advanced all the time and get a little better performance.
Re: Ignition Timing
I have it stated in the instructions that the timing can be advanced, just use common sense. By setting the timing at TDC, the curve advance follows the factory recommendation as close as possible. Advancing is OK, and is accomplished by rotating the module against the rotation of the timing disc (CCW), just like you would with a distributor, using the rotor as a reference direction. I set mine a few degrees advanced and it runs great.
