Hi-Lift mount
Locked
jgeesen
Hi-Lift mount
Post by jgeesen »
Has anyone made a Hi-Lift mount that tucks the jack in wedge the right rear seat makes when it's folded down? That is where I shove mine while wheeling. The drawback is when I need to raise the seats the jack is loose on the floor.
I like the position for the jack. Low and in the rear and out of the waether. I plan on making the brackets easily removable so I can still use the width of the rear pan to slide larger objects in if necessary.
I want to try to utilize the the Quick Fist in the design if I have room. These are Don Polak's design. The website is www.endroad.com
He handed out a few sets at one of out Kentucky treffens a couple years back and I have yet to utilize my set.
Don is the one with the yellow 712 with the stake side bed - nice truck.
high lift
I put the high lift at the rear roll panel up high, just fits in there with the brackets fastened to the top piece. Not in the way when entering or exiting and still very accessible. Also not very visible to the outside world.
Morris, 710M
Locked
