Gear oils again
Locked
MarkPinz
Gear oils again
Post by MarkPinz »
Sorry guys, but since the site crash I can't find my notes as to the gear oil to use in the trans :oops: If I remember right GL5 in everything but the trans which should use GL4 :?:
Draining & replacing everything this morning in prep for a week in the eastern sierra nevada.
Just get in and go....
MarkPinz
Post by MarkPinz »
The above is correct confirmed by master Jim :wink:
rollingpinz
Post by rollingpinz »
Hello
Does this mean that I can't use GL-4 all around?
Eric P
Post by Jim LaGuardia »
GL-4 won't hurt anything, but may discolor from heat sooner.
Cheers, Jim LaGuardia
"Arch Magus of Machines."
rollingpinz
Hello
When you say that it will dis-color sooner, does that mean that it will break-down sooner or simply change color and last just as long as the GL-5 ? The reason I ask is, the manual recommends SAE 80 (Specification MIL-L-2105) for every gear box, even the steering.
Eric P
wd8cdh
Post by wd8cdh »
When the manual was written, GL-5 wasn't around yet. The closest thing to MIL-L-2105 is GL-4. GL-5 is better than GL-4 for almost anything but the syncros in the tranny. GL-5 is too slippery for the syncros.
I use GL-4 (Redline MT-90 synthetic) in my tranny but I use conventional GL-5 in everything else.
Ron Schroeder
WD8CDH
'73 710M
Locked
