wireing a trailer
wireing a trailer
Well I am off to go get my new trailer to pull the balloon around with tomorrow. I am curious if anyone besides SAV or some other mail order place might have the trailer plug. I am unsure as to wire the 12 volt lights in series or invest in more LED's on the trailer.
What have you guys done?
To many decisions....................
Tim Nelson
"ParaPinz"
"ParaPinz"
Lightningpinz
lindenengineering
- David Dunn
British Pacific has the adapter from the Euro "12N" to the flat 4.... I made one years ago with a plug from SAV.
I had also just wired in a flat 4 connector to the junction box under the rear door on another Pinz.
And lastly, if you have an Austrian truck or rewired to run separate brake and indicator lamps, you cannot use the flat4 on a trailer without a convertor to combine the turn/brake lamps (again). It takes 5 wires for a separate turn and brake lamp circuit.
Dave Dunn
Dave Dunn
I changed mine to a standard 6-wire round plug, then put some 24v series 60 ovals in my trailer. the setup has worked flawlessly for 3 years. Soon I'll be putting some multivolts in the trailer so I can choose between my pinz or my cherokee for towing without changing a thing.
Mike Newton 1973 712M (sold)
PinzOED,
I think this may have been mentioned on the LED thread, but this guy's eBay store has several Trailer lights - and a bunch of them are Multi-Volt:
http://stores.ebay.com/LED-AUTO-LIGHTS
- Hope this helps you (and others) find something nice.
Best of all... these prices are very good.
~ TW ~
'73 710K
'73 710K
2012
These are 2 inch 24v LEDs from TruckLite. Grommet mounted and easy to hook up.
