A dealer on ebay specializing in equipment tires found these, and seem to meet all the spec for the need. These are 5.70 -12 ( same physical size as a Semperit 165-12), 6 ply rating and a load range of 1400lbs plus. With the little that I have run these, they are very smooth compared to the Super Lugs, where you could easily lose your lunch after hitting the road on them
All Trax
5.70-12 a Bobcat tire ( yes, the lugs are that deep!)
After so many years of running the All Traxs, these tires seem small
And a comparison of the height difference
Size for size, the sidewalls and beads seems heavier than the Michelin XZLs on the Pink Cow ( why not, they're made for skid steers)
Dave Dunn
btw Randy, the Haf is setup for the ARB too.
