Carb screws
Locked
wwcommando
Carb screws
Post by wwcommando »
I'm having trouble with the front carb cap screws vibrating loose, they loosen up while driving and I loose power on 2 cylinders, has anybody had luck using locktite on these to keep them snug?
Jeff
lindenengineering
Post by lindenengineering »
Don't use loctite on that area, you will live to regret it.
The screw is "turn resisted" by the pressure exerted by the spring.
Try to investigate why it turns, weak/broken spring, junk/debris between the spring coils, or worn components (threads etc).
Those screws are not expensive to replace (if needs be) in fact I think I have a few floating around if you need a pair.
Excuse the pun 'floats -floating, carbs etc"
Dennis
OOOps no customer bashing now
wwcommando
correction
Sorry Dennis, I should have elaborated, these are the 5mm bolts that hold the top cover on the carbs, the original ones vibrated out on a trip to Az, I replaced them with some bolts from NAPA and installed lock washers, before this hunting trip I noticed that 3 were missing again, so I replaced them and they vibrated loose on the way out of the mountains yesterday, It seemed like too much air was getting into the front carb and I lost the power from 2 pistons, The truck started fine, idled fine but no power when I tried to get back on the hwy. I tightened them up again and the truck started running well again, 65 MPH towing a trailered ATV.
Jeff
Locked
