Reverse Switch
Locked
goudacheese
Reverse Switch
Post by goudacheese »
Has anyone installed the reverse backup switch? I have been looking all over the transmission trying to find where it installs and the only bolt that I can find that is big enough is where you fill the transmission! I was told it is above the shaft, but I still don't see it. :!:
Post by Jim LaGuardia »
right above the trans output flange is a 17mm plug, pull that and you will see a plunger. (see picture)
You may have to cut the tail off the plunger to make it work, or if you have a new style one with a recess, just pull the old one out and replace with new one :wink:
Cheers, Jim LaGuardia
"Arch Magus of Machines."
Ugo
Post by Ugo »
I confirm - I had to cut the "tail" with a dremel tool.
BTW, being afraid of risk of dropping the plunger into the gearbox, I put the reverse gear before undoing the screw plug.
Ugo
1977 710K
1990 716K
Torino, Italy
gunipinzmutt
Italy
Post by gunipinzmutt »
Do I have to buy the switch from magna steyr or is it commonly available in the market? I have seen it in the spare parts catalogue with nr 7111850750, Kostal 8860; was it installed also in other cars?
Ugo
Post by Ugo »
I am sure there are several alternatives.
I bought a Fiat Iveco spare part ... small Iveco vans and trucks have a ZF transmission, and presumably ZF use a standardized switch (and thread) on gearboxes they produce.
Ugo
gunipinzmutt
Italy
Thanks Ugo, your help is always useful!
gunipinzmutt
ExpeditionImports
Post by ExpeditionImports »
Readily available switch. Check with the Unimog dealers, same switch as used on the Clauss overdrives....whole lot better price.
Scott
Vallejo, California
www.expedition-imports.com
EuroPinz
Post by EuroPinz »
Hi there;
Here are the parts number:
7161225391 Kontaktbolzen ATS 24.2 (little connecting shaft)
7161850320 Rückfahrschalter ATS 666.4 (reverse switch)
7162850330 Anschlusssatz ATS 186.9 (Reverse switch cover with wires)
Best Regards
Jacques
EuroPinz
Post by EuroPinz »
... here a few more pictures:
Good Luck
Jacques
Locked
