Wooden Side Rails
Wooden Side Rails
Hi All
Has anyone got any technical drawings for the wooden side rails for a 710M?
Any format will do.
Sam
Any format will do.
Sam
If you look in the Yahoo Groups website, there are 2 sources:
The first is in the Photos section titled "Side rubrails" - posted by Hawkwind5USA. This drawing does not account for the 1/4 inch straight part at the base. (Compare these 2, you'll see what I mean)
http://tinyurl.com/39otsb
The second is in the Files section labeled "Pinz Wood Rail Dimensions.jpg" - posted by Matt Shepardson.
http://tinyurl.com/3a6g9s
Your best bet is to work from the specs in both to get the overall-picture of what to cut (with a little fudge factor). Trust me, no one's going to test you on this.
In order to view the links, it's best if you're already logged into the Yahoo Groups site.
- Good luck!
- Good luck!
~ TW ~
'73 710K
'73 710K
That's an awesome idea. I was thinking about some kind of heavy solid rubber (even if the shape isn't exactly right. But using the Trex stuff would last foreever too.russ wrote:I believe they actually used a jig at the factory to keep them all identical. Spacing is the same between all vehicles I've seen. I have made them for 710Ks and Ms and it's pretty easy to do once you have the process down. I've used Trex and another brand of manufactured wood that Home Depot had.
1973 712M
rub rail fun...
its actually a good idea to take them off from time to time, and inspect the metal. the rub rails have a tendency to well... rub... against the base metal, and to trap moisture. in short. a common rust area is under the rub rail.
rub rails
After crushing mine I replaced them with 1 inch by 2 inch steel chanel. Held them off the body with 1/8'' alum washers. I will use them later to add a rack and use the rails as a base for the supports. It is not 'stock' but it seems to work. I thought about Trex, I have seen it done and they look good.
Morris
Morris
Hawkeye Pinz
springhill
