light stays on on the time for the front axle, even when not engaged.
If I need a new switch, will the gear oil run out of the xfer case when I remove old one? Gonna test it this weekend, just thinking ahead.
Front axle engagement switch
1973 712M
Fixed the one that was staying on all the time. Got the rear locker switch that wasn't working to work properly. Just took the covers off cleaned up the leads, and made sure I had good grounds. Does appear that all the switches are seeping a bit. The front one was oily enough I think it was shorting across the leads. I'll wait until I change the lube, and pull them all and replace the o-rings/seals.
1973 712M
