Water is running under and over the double channel the windows set it. The frame under the rubber channel is rusting pretty bad. The door panels are rotted where the water runs in and down over them. Don't want it to get any worse (rust).
Also, pretty annoying when you shut the door and water flings all over you.
Window channel. How to stop leaks?
1973 712M
springhill
I bought the kit from CWR, which replaces the lower channel with a deeper channel and has a drain. You have to take the door panel off and drill a couple of holes in order to run the drain hose out the bottom of the door. It helps a bunch, but does not totally keep you from being splashed. I can't remember what I paid for the two kits.
"Growing Old is Mandatory
Growing Up is Optional"
Door channels
That has always irritated me. It seems like they did such a good job designing the truck and then there are a few odds and ends where they took a break or something. The door channels is one of them.
pinzwheeling
Weird, it's pouring out, and I just came back from a drive to the store. No leaks from the doors whatsoever, the top is a different story.
I know my Pinz was rebodied at one time, and the window design is slightly different, on the bottom front of mine it's rounded instead of squared off. Anyway, I wonder if the newer window tops work better, as I don't appear to have any leakage from that area. If that's the case, maybe you could replace the window tops with newer ones?
