Alternative Clutch/Flyweel alignment tool
Locked
milesdzyn
Post by milesdzyn »
Anyone know which GM Clutch/Flyweel alignment tool works on the pinz. I think it was a GM 10 spline?
Also any other tools that will replace the Pinz specific "gold plated" tools.
ex: VW flywheel holder works for the Pinz.
Miles
Post by Jim LaGuardia »
GM 10 spline , Toyota Landcruiser, Early 60's Mercedes , BMW 8)
Cheers, Jim LaGuardia
"Arch Magus of Machines."
milesdzyn
Post by milesdzyn »
Jim...Will BMW, 3-Series Models (not E36 M3), 1992 -1999 tool work?
Miles
All I Know is the splines on the 733i are the same. I use old input shafts for pilot tools, I use a cut off 64 Mercedes 4 sp input shaft 8)
M Wehrman
Post by M Wehrman »
My last Pinz I used the alignment tool that came with the BMW clutch. I put a few wraps of aluminum tape to make up for the larger pilot bearing and woo,woo! All slid together nicely!
.02 for free!
Mark
Stock means no imagination!
Volvo TGB1317, .95% Morphed!
68 Haffy
milesdzyn
Post by milesdzyn »
Mark....Do you remember the part no of the BMW clutch by chance. I was looking at a HD 4 spring for a BMW M3 but I'm not sure its a direct fit?
http://cgi.ebay.com/ebaymotors/SACHS-87 ... 1674QQrdZ1
Miles
M Wehrman
Post by M Wehrman »
I believe I got the info from the SDP site,If memory serves it was for the 7 series BMW. I bought the kit at Auto Zone,and it had a Sachs pressure plate,and came with a lifetime warrantee!! Of course the T-O bearing wouldn't fit ,but as easy as it was to pull trans ,I opted to reuse my old bearing. BTW,the replacement p-plate was substantially stiffer than my old one. Hope this helps.
Mark
68 Haffy
milesdzyn
Post by milesdzyn »
Thanks Guys
Miles
Locked
