Changing to 125 Main Jets For Altitude, Q's.
Locked
todds112
Post by todds112 »
I have been told these are the correction jets for high altitude. In town here is almost 7,000'. The truck will see that and higher most of the time (up to around 10,000').
When I swap out jets, will I need to re-adjust/sync the carbs? Will this give me a bit of a power boost. Truck did seem to accelerate a bit better at the lower altitude where I bought her. I know it's not going to be a race car, but every little bit helps. I'm more concerned about the further loss of power when I head up further into the mountains.
1973 712M
Kiwibru
Post by Kiwibru »
If 125 jets are for high altitude then my truck certainly needs different jets. Would 120's be better for just above sea level and good up to 3000'?
1975 710M
Post by Jim LaGuardia »
While you can, it is not wise to run 125's below 4000' as overheating due to lean mixture can cause piston and or head damage.
The standard jets for sea level to 5000' are 140's.
Cheers, Jim LaGuardia
"Arch Magus of Machines."
carb jets
How do I know what jets are in the carb now?
Morris
Pull the jet cover and read the number stamped on the end of the jets :wink:
todds112
Post by todds112 »
1973 712M
No, but it is always wise to double check adjustments.
Kiwibru
Post by Kiwibru »
Whoa! 140's huh? Guess I need to swap those out! Thanks Jim.
Bruce
1975 710M
Twin Pinzies
Post by Twin Pinzies »
I run my three 710M's regularly at altitudes from 9,000 ft. to over 13,000 ft. and I am running standard (non- high alt.) jets. They run the same at the top of the passes as they do down in the valleys. I'm not sure I believe that the high altitude jets are even needed!
Kiwibru
Post by Kiwibru »
Well my experience running 125's tells me that they do indeed work better at high altitude. My truck ran really great on the drive back from Arizona, through Neveda, Idaho but...
Once I dropped into the low lands of the Puget Sound area the lower altitude really affected the engine. More hesitation, less power, longer warm up. Just seat of the pants observations, your truck may be different.
1975 710M
todds112
Post by todds112 »
I figure they make them for a reason. Ordered a set today, we'll see how it goes.
1973 712M
Jets vs. float level
The float level makes a BIG difference in how much/little fuel gets through the jets. If you float level is too high you MIGHT get by with 120's at sea level; if you float level is too low it might run OK at altitude with 140's. But if the float level is off you will probably always have some issues and problems. Best bet is to get the float level spot-on and stable (good needle valves, floats not sunk, float pivots OK, etc.) and then get the right jets. Makes a world of difference!
Kiwibru
Post by Kiwibru »
Well we balanced the carbs and checked the float level before I drove the 1100 miles home. I can't imagine that it would have now changed but certainly worth a check. I am torn as to whether swap the main jets or not. The EFI system is coming soon!
1975 710M
todds112
Post by todds112 »
Installed the 125's today. Truck seems to idle better (smoother). Also seemed to warm up faster as well. Wish I could tell you about power from the test drive, but another project (parking brake) forced my hand. :evil:
1973 712M
Locked
